Use the following procedure to display the IP unicast Forwarding Information Base (FIB). The tab shows IP routes from remote Backbone Edge Bridges (BEBs)
The IP Unicast FIB tab displays all of the IS-IS routes in the IS-IS LSDB. The Preference column in the IP Unicast FIB tab displays the IP route preference.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select SPBM.
  3. Select the IP Unicast FIB tab.
IP Unicast FIB Field Descriptions
Use the data in the following table to use the IP Unicast FIB tab.
Name
Description
VrfId
Specifies the VRF ID of the IP unicast FIB entry, 0 indicates NRE.
DestinationIpAddrType
Specifies the address type of the destination IP address.
DestinationIpAddr
Specifies the destination IP Address of the IP unicast FIB entry.
DestinationMask
Specifies the destination IP mask of the IP unicast FIB entry
NextHopBmac
Specifies the nexthop BMAC of the IP unicast FIB entry.
DestId
Specifies the destination I-SID of the IP unicast FIB entry.
Vlan
Specifies the VLAN of the IP unicast FIB entry.
Isid
Specifies the I-SID of the IP unicast FIB entry.
NextHopName
Specifies the nexthop hostname of the IP unicast FIB entry.
OutgoingPort
Specifies the outgoing port of the IP unicast FIB entry.
PrefixCost
Specifies the prefix cost of the IP unicast FIB entry.
SpbmCost
Specifies the BMAC cost of the IP unicast FIB entry.
Preference
Specifies the IP Route preference of the IP unicast FIB entry
MetricType
Specifies the IP Metric Type of the IP unicast FIB entry.
